KO MP Ratbat
тему уже создавал, это восстановленная
Отличная и полезная статья на тфв2005 о КО МП Ретбете
Seems to finally be here:
Transformers Masterpiece MP13B Ratbat Cassettes New in Stock | eBay
I've ordered one so will report back on quality in due course.
EDIT - Fix courtesy of Sponge:
Ok so I want to preface this by saying I have absolutely no problem with the quality of this KO, and that i am simply highlighting issues that others might, as well as presenting my solution to fix the right thruster.
Again this is purely for the sake of informing others what they are in for.
Oh and for the ease of presentation i completely disassembled my figure, pins and all, and while you dont have to do this for the fix, if you do take him apart it is much much easier to fix without damaging the surrounding paint and plastic.
Below you will see that the thrusters are not parallel, upon close examination I have concluded that this is because the hole drilled for pin on the right side was made lower on thruster by mere fractions of a millimeter, making it impossible to pivot all the way, as a result there are two places you can file down to fix it, but more on that later.
attachment.php
Here you can see that front doesnt quite sit flush, and again this is an alignment issue, as one side sits closer to the body than the other.
attachment.php
Some uncut sprue easily fixed
attachment.php
Stress marks and a crack on the wing....
attachment.php
Its the same on all 5 screw points, oh and they were all stripped right out of the box, I recommend loctite for a quick fix, if only a temporary one.
attachment.php
Ok now the fix, so the magenta bit inbetween the gold is where you want to file, if you dont take it apart the easiest way to get at it is folding a piece of sandpaper around something thin and using the edge sand inbetween the gold, however doing this you may damage the surrounding area, so I recommend taking it apart if you can and then simply taking a file or some emeryboard to it.
attachment.php
The other place you can sand is the inbetween the sides of the thruster itself. this however requires that you disassemble it first, the upside is that it is less noticeable when done.
attachment.php
This is after sanding.
attachment.php
More noticeable difference.
attachment.php
The finished result, parallel at last!
attachment.php
I hope this helps all of you out there in some way, if you need more specific pics or clarification let me know and I'll do my best to address your needs.
At the end of the day id say its worth the 20$.
Останнє редагування модератором:
Думал своему подпилить эти ускорители, а потом подумал лучше и понял что и так все ок)))
